Pinout budik A8 4D0919033CA
Příspěvek od amigo »
Zdar.Nema niekto pinout budika A8 4D0919033CA.Stači napajanie.Diky.
maros4341
Příspěvek od maros4341 »
nech sa páči
snáď angličtina nie je problém:
→ Multi-pin connector,
32-pin, blue
1 - Left turn signal
2 - Right turn signal
3 - Coolant temperature
4 - Fuel gauge sender
5 - Sensor earth (terminal 31)
8 - Fog light
9 - Rear fog light
10 - Airbag
12 - High beam
13 - Trailer turn signal
14 - Handbrake
15 - Terminal 61
17 - Brake pad
18 - Brake fluid level
19 - Oil pressure switch
20 - Belt buckle
22 - Headlight range control
23 - Brake light
24 - Low beam
26 - Terminal 15
27 - Terminal 15
28 - Earth (terminal 31)
29 - Earth (terminal 31)
30 - Battery + (terminal 30)
31 - Battery + (terminal 30)
32 - Battery + (terminal 30)
32-pin, green
1 - Transponder 1
2 - K-wire
5 - Ambient temperature sender
6 - Terminal 86s
7 - Auxiliary heating radio input
11 - Oil level
12 - Function selection switch (Out B)
13 - Function selection switch (Out A)
14 - Function selection switch (Enter)
15 - On-board computer (left)
16 - On-board computer (right)
17 - Transponder 2
18 - CAN bus Low (drive train)
20 - CAN bus High (drive train)
21 - CAN bus Low (display)
22 - CAN bus High (display)
23 - CAN bus High (convenience)
24 - CAN bus Low (convenience)
27 - On-board computer (Reset)
28 - Function selection switch (menu)
31 - Right-hand parking light
32 - Left-hand parking light
32-pin, grey
1 - Function selection switch (Telematics)
2 - Function selection switch (menu)
3 - Function selection switch (menu)
4 - Bonnet switch
5 - Navigation data (up to MY 2000)
7 - Speed signal input
8 - Air conditioner output
9 - Speed signal output
10 - Fan speed 3
11 - Boot lid
12 - Summer/Winter setting
14 - Terminal 58
15 - Driver's door
16 - "Time parked" output
17 - Washer fluid level
18 - Coolant level
19 - ABS
20 - TCS
21 - Clock (until MY 2000)
22 - Enable (until MY 2000))
23 - Terminal 58s
24 - Terminal 58s
25 - Terminal 58s
26 - Terminal 58d
27 - Terminal 58d
28 - Door lock signal
29 - Rear right door
30 - Rear left door
31 - Front passenger's door
32 - Auxiliary heater output
4-pin, black
1 - Radio-controlled clock signal (data)
2 - Radio-controlled clock, 5V
4 - Radio-controlled clock, earth
maros
Rozumieme Vášmu autu
Diky moc
Příspěvek od vaha »
Ty budeš mít ale jiné zapojení myslím...
Tak nefunguje
Příspěvek od vaha »
Protože ti poslal zapojení novějších budíku ty máš žlutý a modrý konektor
maros4341
hlboko sa ospravedlnujem za svoj omyl
tu je naprava.....
A ja som si myslel ze taketo informacie si clovek z nasho fachu vie lahko zaobstarat aj sam......
Dash panel insert
Contact assignment on connectors in dash panel insert (vehicles 1997 >)
A - Multi-pin connector for basic functions 26-pin, yellow
B - Multi-pin connector for basic functions 26-pin, red
C - Multi-pin connector for basic functions 26-pin, green
D - Multi-pin connector for power supply, 6-pin, white
E - Multi-pin connector for radio clock, 4-pin, white
→ Multi-pin connector for basic functions, 26-pin, yellow -A
1 - Tank sender signal
2 - Tank sender earth
3 - Door contact, driver's side
4 - Ignition key terminal 86s
5 - Hydraulic system/brake fluid level
6 - Belt switch
8 - Right-hand parking light
9 - On-board computer, left rocker
10 - On-board computer, right rocker
11 - On-board computer reset
12 - Temperature sender earth
13 - Tank sender (reserve fuel contact)
14 - Ambient temperature sensor/air conditioner
15 - Diesel (glow plug relay
16 - (Buzzer "ON")
17 - Temperature sender
18 - Cooling water level
19 - Brake light
20 - Reversing light/dipped beam
21 - Left-hand parking light
22 - Fan, speed 3
23 - Oil temperature (earth)
24 - Oil temperature
25 - Ambient temperature sensor earth
26 - Air-conditioner compressor "OFF"
→ Multi-pin connector for basic functions 26-pin, red-B
1 - Tailgate
2 - Door contact, passenger's side
3 - Door contact, rear left
4 - Door contact, rear right
5 - Tank level (for OBD II)
6 - Vacant
7 - Oil pressure 1.2 bar
8 - Vacant
9 - Gear indicator
10 - Vacant
11 - Auxiliary heater (radio input)
12 - Hydraulic system pressure
13 - Service life signal as of ABS system 5.3 vacant with ABS system 5.0
14 - Navigation enable
15 - Navigation clock
16 - Navigation data
17 - Summer/winter
18 - Rev counter signal
19 - Consumption signal
20 - Auxiliary heater
21 - Vacant
22 - Speed signal (output 2)
23 - Speed signal (output 1)
24 - Speed signal (sender)
25 - Brake pad
26 - K wire
→ Multi-pin connector for basic functions 26-pin, green - C
1 - Vacant
2 - Vacant
3 - Vacant
4 - Vacant
5 - Vacant
6 - Airbag
7 - ABS
8 - Door lock (output)
9 - Left turn signal
10 - Vacant
11 - Vacant
12 - Vacant
13 - Vacant
14 - Vacant
15 - TCS
16 - OBD II
17 - Trailer turn signal
18 - CAT/diesel
19 - Main beam
20 - Parking brake and brake warning (for brake fluid pressure and level)
21 - Charge indicator
22 - Right turn signal
23 - Vacant
24 - Immobilizer
25 - Airbag (active)
26 - ABS (Sila)
→ Multi-pin connector for power supply, 6-pin, white - D
1 - Terminal 30
2 - Terminal 31
3 - Lighting (3W)
4 - Lighting, console (40W)
5 - Terminal 58
6 - Terminal 15
maros
Nie nie.Konektor zelena,modra,siva. Rok 2000.
Naposledy upravil(a) amigo dne pát pro 20, 2019 21:27 pm, celkem upraveno 1 x.
maros4341
takze som sa predsa nezmylil v prvom prispevku.....
Zapojenie je hned v prvom mojom prispevku.
Aspon bude toto vlákno zdrojom informácii pre budúcich majstrov
maros
Ano.Ale po zapojeni 15,30,31 nic.V aute idu normalne,len podsvietenie displaya nic.Preto to chcem na stole riešit.Musim ku autu a tam to odmeriam.
