| Obsah fóra checksum.cz » Panely přístrojů, immo » Pinout budik A8 4D0919033CA |
Strana 1 z 1 |
| amigo |
Zaslal: st prosinec 18, 2019 14:06 pm |
Založen: 19.6.2009
| Zdar.Nema niekto pinout budika A8 4D0919033CA.Stači napajanie.Diky.
| maros4341 |
Zaslal: čt prosinec 19, 2019 18:15 pm |
Založen: 23.2.2007
nech sa páči
snáď angličtina nie je problém:
→ Multi-pin connector,
32-pin, blue
1 - Left turn signal
2 - Right turn signal
3 - Coolant temperature
4 - Fuel gauge sender
5 - Sensor earth (terminal 31)
8 - Fog light
9 - Rear fog light
10 - Airbag
12 - High beam
13 - Trailer turn signal
14 - Handbrake
15 - Terminal 61
17 - Brake pad
18 - Brake fluid level
19 - Oil pressure switch
20 - Belt buckle
22 - Headlight range control
23 - Brake light
24 - Low beam
26 - Terminal 15
27 - Terminal 15
28 - Earth (terminal 31)
29 - Earth (terminal 31)
30 - Battery + (terminal 30)
31 - Battery + (terminal 30)
32 - Battery + (terminal 30)
32-pin, green
1 - Transponder 1
2 - K-wire
5 - Ambient temperature sender
6 - Terminal 86s
7 - Auxiliary heating radio input
11 - Oil level
12 - Function selection switch (Out B)
13 - Function selection switch (Out A)
14 - Function selection switch (Enter)
15 - On-board computer (left)
16 - On-board computer (right)
17 - Transponder 2
18 - CAN bus Low (drive train)
20 - CAN bus High (drive train)
21 - CAN bus Low (display)
22 - CAN bus High (display)
23 - CAN bus High (convenience)
24 - CAN bus Low (convenience)
27 - On-board computer (Reset)
28 - Function selection switch (menu)
31 - Right-hand parking light
32 - Left-hand parking light
32-pin, grey
1 - Function selection switch (Telematics)
2 - Function selection switch (menu)
3 - Function selection switch (menu)
4 - Bonnet switch
5 - Navigation data (up to MY 2000)
7 - Speed signal input
8 - Air conditioner output
9 - Speed signal output
10 - Fan speed 3
11 - Boot lid
12 - Summer/Winter setting
14 - Terminal 58
15 - Driver's door
16 - "Time parked" output
17 - Washer fluid level
18 - Coolant level
19 - ABS
20 - TCS
21 - Clock (until MY 2000)
22 - Enable (until MY 2000))
23 - Terminal 58s
24 - Terminal 58s
25 - Terminal 58s
26 - Terminal 58d
27 - Terminal 58d
28 - Door lock signal
29 - Rear right door
30 - Rear left door
31 - Front passenger's door
32 - Auxiliary heater output
4-pin, black
1 - Radio-controlled clock signal (data)
2 - Radio-controlled clock, 5V
4 - Radio-controlled clock, earth
_________________ maros
Rozumieme Vášmu autu
| amigo |
Zaslal: čt prosinec 19, 2019 18:35 pm |
Založen: 19.6.2009
| Diky moc
| vaha |
Zaslal: čt prosinec 19, 2019 18:56 pm |
Založen: 6.5.2007
| Ty budeš mít ale jiné zapojení myslím...
| amigo |
Zaslal: čt prosinec 19, 2019 19:06 pm |
Založen: 19.6.2009
| Tak nefunguje
| vaha |
Zaslal: pá prosinec 20, 2019 20:33 pm |
Založen: 6.5.2007
| Protože ti poslal zapojení novějších budíku ty máš žlutý a modrý konektor
| maros4341 |
Zaslal: pá prosinec 20, 2019 20:49 pm |
Založen: 23.2.2007
hlboko sa ospravedlnujem za svoj omyl
tu je naprava.....
A ja som si myslel ze taketo informacie si clovek z nasho fachu vie lahko zaobstarat aj sam......
Dash panel insert
Contact assignment on connectors in dash panel insert (vehicles 1997 >)
A - Multi-pin connector for basic functions 26-pin, yellow
B - Multi-pin connector for basic functions 26-pin, red
C - Multi-pin connector for basic functions 26-pin, green
D - Multi-pin connector for power supply, 6-pin, white
E - Multi-pin connector for radio clock, 4-pin, white
→ Multi-pin connector for basic functions, 26-pin, yellow -A
1 - Tank sender signal
2 - Tank sender earth
3 - Door contact, driver's side
4 - Ignition key terminal 86s
5 - Hydraulic system/brake fluid level
6 - Belt switch
8 - Right-hand parking light
9 - On-board computer, left rocker
10 - On-board computer, right rocker
11 - On-board computer reset
12 - Temperature sender earth
13 - Tank sender (reserve fuel contact)
14 - Ambient temperature sensor/air conditioner
15 - Diesel (glow plug relay
16 - (Buzzer "ON")
17 - Temperature sender
18 - Cooling water level
19 - Brake light
20 - Reversing light/dipped beam
21 - Left-hand parking light
22 - Fan, speed 3
23 - Oil temperature (earth)
24 - Oil temperature
25 - Ambient temperature sensor earth
26 - Air-conditioner compressor "OFF"
→ Multi-pin connector for basic functions 26-pin, red-B
1 - Tailgate
2 - Door contact, passenger's side
3 - Door contact, rear left
4 - Door contact, rear right
5 - Tank level (for OBD II)
6 - Vacant
7 - Oil pressure 1.2 bar
8 - Vacant
9 - Gear indicator
10 - Vacant
11 - Auxiliary heater (radio input)
12 - Hydraulic system pressure
13 - Service life signal as of ABS system 5.3 vacant with ABS system 5.0
14 - Navigation enable
15 - Navigation clock
16 - Navigation data
17 - Summer/winter
18 - Rev counter signal
19 - Consumption signal
20 - Auxiliary heater
21 - Vacant
22 - Speed signal (output 2)
23 - Speed signal (output 1)
24 - Speed signal (sender)
25 - Brake pad
26 - K wire
→ Multi-pin connector for basic functions 26-pin, green - C
1 - Vacant
2 - Vacant
3 - Vacant
4 - Vacant
5 - Vacant
6 - Airbag
7 - ABS
8 - Door lock (output)
9 - Left turn signal
10 - Vacant
11 - Vacant
12 - Vacant
13 - Vacant
14 - Vacant
15 - TCS
16 - OBD II
17 - Trailer turn signal
18 - CAT/diesel
19 - Main beam
20 - Parking brake and brake warning (for brake fluid pressure and level)
21 - Charge indicator
22 - Right turn signal
23 - Vacant
24 - Immobilizer
25 - Airbag (active)
26 - ABS (Sila)
→ Multi-pin connector for power supply, 6-pin, white - D
1 - Terminal 30
2 - Terminal 31
3 - Lighting (3W)
4 - Lighting, console (40W)
5 - Terminal 58
6 - Terminal 15
| amigo |
Zaslal: pá prosinec 20, 2019 21:24 pm |
Založen: 19.6.2009
| Nie nie.Konektor zelena,modra,siva. Rok 2000.
Naposledy upravil amigo dne pá prosinec 20, 2019 21:27 pm, celkově upraveno 1 krát.
| maros4341 |
Zaslal: pá prosinec 20, 2019 21:27 pm |
Založen: 23.2.2007
takze som sa predsa nezmylil v prvom prispevku.....
Zapojenie je hned v prvom mojom prispevku.
Aspon bude toto vlákno zdrojom informácii pre budúcich majstrov
| amigo |
Zaslal: pá prosinec 20, 2019 21:29 pm |
Založen: 19.6.2009
| Ano.Ale po zapojeni 15,30,31 nic.V aute idu normalne,len podsvietenie displaya nic.Preto to chcem na stole riešit.Musim ku autu a tam to odmeriam.
Právě je ne srpen 23, 2026 13:47 pm
