NITROobd2
probírejte cokoliv
dreizig5
NITROobd2
Příspěvek od dreizig5 »
tak takhle se to dneska dělá
http://www.obd2buy.com/en/37-obd2-tuning
:lol:
Příspěvek od DIGI-DELETED »
tady je na to projekt : http://danyk.cz/schem/64
to bys koukal jak to zrychlí can v autě :lol: :lol:
tpower
Příspěvek od tpower »
A jsme bez prace, jedno pri pouziti rozdvojky obd vygeneruje i 70% vykonu navic a druhy je vychytavka pro elektromobily :D Kdyz to digiho zapojeni napojime obracene do vetrny elektrarny jako napajeni, tak mame prinejmensim uragan :D
www.tdichip.cz, www.tpower.cz
Příspěvek od anydraj »
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
Aspon jste mi zlepsily naladu
FandaTDI
Příspěvek od FandaTDI »
By mě zajímalo, jestli je tam za těch 7 babek aspoň ten resetovací čudlík :lol:
To musí mít ku*va chytrý střeva, když to "tuní samo podle návyků řidiče" :lol: :lol: :lol:
"What does NitroOBD2 make?
According to your driving habits, NitroOBD2 makes new map in the car's computer ECU to increase the performance of your car. As you driving much more KM/Mile, it renews the map. Thus it keeps the vehicle's power and torque increasing."
:roll:
Nedalo mi to a zkusil jsem chat :-) :
You (change name)
01:26
Hi, can you please give a photo of PCB (if any :-) )/inside of this "feature"? - http://www.obd2buy.com/en/obd2-tuning/7 ... drive.html
thanks
Chad has joined the conversation
01:27
Chad
01:27
Have no pcb photo now
Will you clone it?:)
It is my own production
First in the planet
You (change name)
01:28
How can I (from a photo of PCB) when it is so smart that it increase performance in accordance to driving habits? :-)
Chad
01:30
:) just kidding
Buy 1 pcs sample and test your own car
We are in dyno reservation line
You (change name)
01:31
blank OBD? (what can be expected for 7 bucks?) ;-)
Is there even the reset button? :-)
Chad
01:35
Yes reset botton for adaptation
It really works mate
Old technology selling around 200 pounds in ebay
You may have alook feedback of that sellers
Search "obd2 tuning"
You (change name)
01:44
AFAIK not really possible even with ECUs rewritable via OBD ;-)
http://www.obd2tuning.com/ ?
Chad
01:42
It does not write
Use data over obd device
Oh
Come to china and lead my factory
This is trade secret
Will be ready dyno results soon
That will be better for
You (change name)
01:50
Has it even converter from K to CAN? ;)
Chad has left the conversation
:lol:
dreizig5
tohle je pravej čech.litr navrch a už jede :lol:
http://www.sbazar.cz/diag.king2/detail/ ... izeni-plug
a vy si tady z toho děláte prdel :D :D :D
Prodám za 1 200 Kč
NitroOBD2 DIESEL - BENZIN je zařízení Plug & Drive na zvýšení výkonu motoru a snížení spotřeby. Stačí zapojit do diagnostické zásuvky v autě, je určený pro všechny automobily od roku výroby 1996. Funguje tak,že OBD2 protokoly zakládají remaping (přeprogramování počítače ECU). Po ujetí 200 km se přizpůsobí k autu podle zvyklostí řidiče a nastaví řídící jednotku tak aby zvýšila výkon a snížila spotřebu. Jakmile je zařízení zapojeno do OBD2 konektoru, NitroOBD2 obdrží informace z řídící jednotky. U přijatých dat upravuje plnicí tlak, množství paliva, časování vstřiku. NitroOBD2 nepřesahuje požadavky výrobce. Funguje pouze v rámci tolerance motoru, nepoškozuje motor a nemá žádné negativní účinky na nastavení automobilu. Chcete-li se vrátit k původnímu nastavení vozu, stačí odpojit NitroOBD2. Vlastnosti Produktu: - Až 35% více výkonu - Až o 25% větší točivý moment - Snížení spotřeby až o 15% -
diagking2
:lol: :lol: :lol:
dreizig5
Sayllo
Příspěvek od Sayllo »
DIGI-DELETED píše:Prodám za 1 200 Kč
diagking2
:lol: :lol: :lol:
Aaaaaa, no ja by som natom rad zacal zarabat inak, mozete mi povedat ako dostanem tie vytunene mapy stej ecu na USB aby som mohol zacat tunit na pockanie pri obchodaku, alebo priamo poštou na dobierku?
Know-how kamo.
Sayllo
anydraj píše:Know-how kamo.
https://www.youtube.com/watch?v=Eafb_Y5axJs
