Obsah fóra checksum.cz  »  Diskuze mimo mísu  »  NITROobd2
NITROobd2
dreizig5
Zaslal: po květen 25, 2015 18:50 pm Citovat
tak takhle se to dneska dělá
http://www.obd2buy.com/en/37-obd2-tuning
Laughing
Zaslal: po květen 25, 2015 20:31 pm Citovat
tady je na to projekt : http://danyk.cz/schem/64
to bys koukal jak to zrychlí can v autě Laughing Laughing
tpower
Zaslal: po květen 25, 2015 22:32 pm Citovat
A jsme bez prace, jedno pri pouziti rozdvojky obd vygeneruje i 70% vykonu navic a druhy je vychytavka pro elektromobily Very Happy Kdyz to digiho zapojeni napojime obracene do vetrny elektrarny jako napajeni, tak mame prinejmensim uragan Very Happy
www.tdichip.cz, www.tpower.cz
Zaslal: út květen 26, 2015 8:12 am Citovat
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Aspon jste mi zlepsily naladu
FandaTDI
Zaslal: čt květen 28, 2015 0:59 am Citovat
By mě zajímalo, jestli je tam za těch 7 babek aspoň ten resetovací čudlík Laughing
To musí mít ku*va chytrý střeva, když to "tuní samo podle návyků řidiče" Laughing Laughing Laughing
"What does NitroOBD2 make?
According to your driving habits, NitroOBD2 makes new map in the car's computer ECU to increase the performance of your car. As you driving much more KM/Mile, it renews the map. Thus it keeps the vehicle's power and torque increasing."
Rolling Eyes
Nedalo mi to a zkusil jsem chat Smile :
You (change name)
01:26
Hi, can you please give a photo of PCB (if any Smile )/inside of this "feature"? - http://www.obd2buy.com/en/obd2-tuning/71-nitroobd2-diesel-chip-tuning-box-plug-and-drive.html
thanks
Chad has joined the conversation
01:27
Chad
01:27
Have no pcb photo now
Will you clone it?Smile
It is my own production
First in the planet
You (change name)
01:28
How can I (from a photo of PCB) when it is so smart that it increase performance in accordance to driving habits? Smile
Chad
01:30
Smile just kidding
Buy 1 pcs sample and test your own car
We are in dyno reservation line
You (change name)
01:31
blank OBD? (what can be expected for 7 bucks?) Wink
Is there even the reset button? Smile
Chad
01:35
Yes reset botton for adaptation
It really works mate
Old technology selling around 200 pounds in ebay
You may have alook feedback of that sellers
Search "obd2 tuning"
You (change name)
01:44
AFAIK not really possible even with ECUs rewritable via OBD Wink
http://www.obd2tuning.com/ ?
Chad
01:42
It does not write
Smile
Use data over obd device
Oh
Come to china and lead my factory
Smile
This is trade secret
Will be ready dyno results soon
That will be better for
You (change name)
01:50
Has it even converter from K to CAN? Wink
Chad has left the conversation
Laughing
dreizig5
Zaslal: st červen 17, 2015 17:34 pm Citovat
tohle je pravej čech.litr navrch a už jede Laughing
http://www.sbazar.cz/diag.king2/detail/11115834-nitroobd2-diesel-benzin-je-zarizeni-plug
a vy si tady z toho děláte prdel Very Happy Very Happy Very Happy
Zaslal: st červen 17, 2015 21:58 pm Citovat
Prodám za 1 200 Kč
NitroOBD2 DIESEL - BENZIN je zařízení Plug & Drive na zvýšení výkonu motoru a snížení spotřeby. Stačí zapojit do diagnostické zásuvky v autě, je určený pro všechny automobily od roku výroby 1996. Funguje tak,že OBD2 protokoly zakládají remaping (přeprogramování počítače ECU). Po ujetí 200 km se přizpůsobí k autu podle zvyklostí řidiče a nastaví řídící jednotku tak aby zvýšila výkon a snížila spotřebu. Jakmile je zařízení zapojeno do OBD2 konektoru, NitroOBD2 obdrží informace z řídící jednotky. U přijatých dat upravuje plnicí tlak, množství paliva, časování vstřiku. NitroOBD2 nepřesahuje požadavky výrobce. Funguje pouze v rámci tolerance motoru, nepoškozuje motor a nemá žádné negativní účinky na nastavení automobilu. Chcete-li se vrátit k původnímu nastavení vozu, stačí odpojit NitroOBD2. Vlastnosti Produktu: - Až 35% více výkonu - Až o 25% větší točivý moment - Snížení spotřeby až o 15% -
diagking2
dreizig5
Zaslal: po červen 29, 2015 20:41 pm Citovat
hoši toto se neodmíta 16pcs!!!
http://www.obd2buy.com/en/categories/69-ecoobd2-nitroobd2-chip-tuning-box-benzine-diesel-16-pcs.html
Sayllo
Zaslal: st září 23, 2015 15:25 pm Citovat
Prodám za 1 200 Kč
diagking2
Aaaaaa, no ja by som natom rad zacal zarabat inak, mozete mi povedat ako dostanem tie vytunene mapy stej ecu na USB aby som mohol zacat tunit na pockanie pri obchodaku, alebo priamo poštou na dobierku?
Zaslal: st září 23, 2015 15:28 pm Citovat
Know-how kamo.
Sayllo
Zaslal: st září 23, 2015 22:20 pm Citovat
anydraj napsal:
Know-how kamo.
https://www.youtube.com/watch?v=Eafb_Y5axJs
Právě je čt říjen 08, 2026 11:17 am
