Obsah fóra checksum.cz  »  Komfortní systém  »  golf VII
golf VII
lala
Zaslal: út srpen 13, 2019 16:45 pm Citovat
Založen: 20.12.2008 Příspěvky: 74
Ahoj kluci nedělal někdo zavírání oken při dešti?
Dělal jsem to podle tohoto návodu vše přepsáno na displeji radia se to zobrazuje,ale okna nezavřou Sad
tomatic rain closing mot working
Coded my 2015 PP GTI to auto close the windows when it rains. Trying to test by pouring a cup of water on the top of the windscreen. But the windows arent closing? Coded as follows from the following links...
Will a cup a water activate the auto closing function on the windows?
6. Automatic rain closing
Go into [09] Central Electronics
Go into Secuity Access and enter 31347
Go to adaptation channels and set the following:
- (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
- (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
- (2Cool Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set to Active (enables the menu in the ifotainment screen)
9 Central Electronics
Rain and light sensor
Byte 0…Enable Bit 2 “Regenschliessen aktiv”. (rain closing active)
Bit 1 should be active too….Regenlicht aktiv (rain light active)
My Old coding…..00A8DD
My New coding….06A8DD
I changed the code to match the last line here, this was the last thng i did.
https://sites.google.com/a/naturalne...o-rain-closing
http://www.golfmk7.com/forums/showthread.php?t=2491
Maybe my test is flawed?
Právě je čt říjen 08, 2026 10:50 am
