pin pro adaptaci z 03G906016GP
Zdravim a prosim o pomoc. Potreboval bych vycist pin z ridici jednotky 03G906016GP 16u1 (stary pin 2K0920842A VWZ7Z0E2170392) pro adaptaci nove pristrojovky 2K0920840E VWZ7Z0D9217674. Jedna se vw caddy 2004 , stara nenavratne umrela , z nove se mi podarilo vycist immodata (a tedy pin), ze stare mam jen bin 24lc32 a z ridici jednotky eeprom bin ST95320WP. Bude to stacit pro vycteni stareho pinu? Nebo napada vas nejaka cesta jak provest adaptaci? Diky moc
- Přílohy
- up_eeprom1.rar
- (814 bajtů) Staženo 30 x
- 24lc32a_01.rar
- (1.25 KiB) Staženo 27 x
pin ecu CS MAC i immo off
bud tam nahraj immo off nebo zmen data
- Přílohy
- CS Mac Pin.rar
- (123 bajtů) Staženo 27 x
- up_eeprom1 immo OFF PIN 02926.rar
- (899 bajtů) Staženo 31 x
Super diky. Pin je v poradku. Dnes teda jeste zkusim immo off. Protoze pres vcds mi to nejak nejde. Urcite se ozvu jak jsem dopadl. Drive bohuzel nebyl cas.
Sunday,23,March,2025,13:08:20:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20200331
VIN: WV2ZZZ2KZ6X001784 License Plate:
Mileage: 518630km-322261mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52
VIN: WV2ZZZ2KZ6X001784 Mileage: 518630km/322261miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-GP.clb
Part No SW: 03G 906 016 GP HW: 028 101 216 8
Component: R4 2,0L EDC 0000SG 7001
Revision: 12345678 Serial number: VWZ7Z0E2170392
Coding: 0053031
Shop #: WSC 00000 000 00000
VCID: 77FD0D5706389FA6A59-8022
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 120.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00191
VCID: 3F8DA5776E8867E6AD9-806A
7 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
00283 - ABS Wheel Speed Sensor; Front Left (G47)
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
01044 - Control Module Incorrectly Coded
008 - Implausible Signal - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001886410
Coding: 09884F030004100000000000000000000008FF075C
Shop #: WSC 22268 401 71177
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 2K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 22268
9 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
OFF
OFF
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
OFF
OFF
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 518637 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 0A AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD06V29E
Coding: 0012353
VCID: 7DF11F7F2404B5F6FF5-8028
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 E HW: 1K0 953 549 E
Component: Lenksäulenmodul 021 0050
Coding: 0000002
Shop #: WSC 35110 377 08192
VCID: 3467FA5B57CEB4BE40B-8061
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 2K0 920 840 E
Component: KOMBIINSTRUMENT VDD 3554
Coding: 0000001
Shop #: WSC 51721 002 104857
VCID: 29591B2F800CF956E3D-807C
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010550202EA
Coding: 3D0F0100079000
VCID: 2A5BE423850AF24EEA7-807F
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0159
Coding: 0000000
VCID: F6E38053813266AE3EF-80A3
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00890C087F2D84054848016010C0
Shop #: WSC 22268 401 15627
VCID: 79F90B6F302C89D6D3D-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: F5E1875F9C346DB6375-80A0
End ---------------------------------------------------------------------
Coding: 0053031
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 120.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 0.0
Coding: 0017106
7 Faults Found:
Coding: 00065493
Shop #: WSC 22268
9 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.40 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 518637 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.35 V
OFF
ON
OFF
OFF
OFF
Coding: 0012353
Coding: 0000002
Coding: 0000001
1 Fault Found:
014 - Defective
Cannot be reached
Coding: 0000000
Cannot be reached
Component: KSG 0401
1 Fault Found:
Coding: 0000000
Re: pin ecu CS MAC i immo off
manhunt2 píše:bud tam nahraj immo off nebo zmen data
Diky za *.bin ale stara pristrojovka (2K0920842A) mela 4kb nova(2K0920840E) ma 2kb. Sly by prosim data upravit na novou pristrojovku ? protoze pres vcds mi to nejak nejde. idealne pouze immo data pro vag+k commander. diky
ten eeprom soubor immo off je k ridici jednotce motoru,pokud chces nahrat jine budiky a nemas immodata z puvodnich tak nejjednodussi postup je nahrat do budiku novy cip a pak k budikum prizpusobit ecu timpadem win atd bude z novych budiku.pokud chces nechat puvodni win atd z ecu motoru tak musis immodata prepsat v budikach CS MAC PW ale s vcds to nejde.
Re: pin pro adaptaci z 03G906016GP
Uplne nejlepsi by byl immo off (i v pripade nutnosti nahrani do ridici jednotky motoru -tohle zvladnu) soubor vyse immo off je zaheslovany v rar. Muzu poprosit o heslo? Pokud tohle bude stacit k uspesnemu nastartovani motoru, je to luxus a netreba legalizovat budiky.manhunt2 píše:ten eeprom soubor immo off je k ridici jednotce motoru,pokud chces nahrat jine budiky a nemas immodata z puvodnich tak nejjednodussi postup je nahrat do budiku novy cip a pak k budikum prizpusobit ecu timpadem win atd bude z novych budiku.pokud chces nechat puvodni win atd z ecu motoru tak musis immodata prepsat v budikach CS MAC PW ale s vcds to nejde.
Vycist, prepsat a nahrat budiky jsem zkousel v k+can commanderu 1.4 . Urcite delam neco spatne, po editaci a nahraní do budiku, mi vzdy zmizela (prestala svitit) kontrolka immo , ale vcds porat psal chybu immo-start motoru.
Muzu teda poprosit o to heslo k souboru immo off pro nahrani do ridici jednotky motoru? To je posledni vec co jeste muzu udelat. Naivne jsem si myslel, ze pin ze starych mi pomuze k adaptaci.
Zatim diky moc.
heslo winrar
.1973.
Re: heslo winrar
SUPER. Diky moc funguje.manhunt2 píše:.1973.
