OPEL Z14XEP
shrek
OPEL Z14XEP
Příspěvek od shrek »
Zdar, potkal jste se někdo s tím to?
Normálně to jezdí ale svítí MIL.....
Nemáte někdo schéma zapojení RJ ?
Identifier: 0x0A35
VIN:
Hardware number:61208941
Part Number:55557934
Software version number: 42070601
Motor type: Z14XEP
Hardware manufacturer number: 0261208941
Hardware key number: 19RR9319
System description: BOSCH0100
Type approval number: B07003
Alpha code: AY
Manufacturing date: 20090108
Hardware manufacturer system name: ME7.6.2
Total number of fault codes: 5
P0489 - Exhaust Gas Recirculation Circuit Low Voltage
(00) - Present
P0037 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
(00) - Present
P0031 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)
(00) - Present
P2009 - Port Deactivation Solenoid Valve Circuit Low Voltage
(00) - Present
P0458 - Fuel Tank Ventilation Valve Voltage Low
(00) - Present
:oops: :?: :cry:
