Obsah fóra checksum.cz  »  Panely přístrojů, immo  »  SII kontrola žárovek
Zaslal: po březen 26, 2012 8:03 am Citovat
Nevíte někdo jak se dá vypnout kontrola žárovek na Superbu II rv 2010??Pán si namontoval zadní LED lampy pro čínský trh a svítí mu kontrolka,ale nějak jsem to nenašel v kódování
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 E HW: 1K0 937 087 E
Component: BCM PQ35 H+ 103 0537
Revision: 00103 AC
Coding: 46990AB8F841F1C040080084110089A403711BAE63208F605C4040000000
Shop #: WSC 33361 790 00999
VCID: 33608485922E49B
Subsystem 1 - Part No: 3T1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 20060 22 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250609 05 54 0402
Coding: 072BED
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
4 Faults Found:
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 11
Reset counter: 96
Mileage: 39778 km
Time Indication: 0
Date: 2027.14.08
Time: 11:00:52
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
Term 50 Off
OFF
OFF
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 96
Mileage: 39778 km
Time Indication: 0
Date: 2027.14.08
Time: 11:00:52
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
Term 50 Off
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 96
Mileage: 39778 km
Time Indication: 0
Date: 2027.14.08
Time: 11:00:52
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
Term 50 Off
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 96
Mileage: 39778 km
Time Indication: 0
Date: 2027.14.08
Time: 11:00:52
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
Term 50 Off
OFF
OFF
Právě je čt září 10, 2026 6:07 am
