Obsah fóra checksum.cz  »  Hardware  »  Audi A8 A/V vstup
Audi A8 A/V vstup
cimohutka
Zaslal: čt prosinec 16, 2010 21:10 pm Citovat
Založen: 4.2.2009 Příspěvky: 2 Bydliště: Garadna
Chcel by som sa opytat ci nemal niekto podobny problem, chcem domontovat dvd mechaniku macrom m-dvd9001, malo by sa pripajat na a/v vstup do tv tunera (na piny konektora) bez nejakeho interface, len neviem kde pripojit kable, napajanie nieje problem, len neviem kde pripojit audio a video vystup z dvd playera na vstup tv tunera,
Audi A8, 3.7, 2003, TV tuner, navigacia, bez cuvacej kamery
dik za vsetky rady, googlim uz niekolko dni a stale nic, len stale nejaky interface
Skoda Felicia TMBEFF613V7... bez tuningu, ABS, stabilizator prednej napravy
maros4341
Zaslal: čt prosinec 16, 2010 22:30 pm Citovat
Vitaj na fore.
20 pinovy konektor na analogovom TV tuneri vzadu vlavo
A - Multi-pin connector, 20-pin with RSE, red (T20f)
1 - Terminal 30
2 - Terminal 31
3 - Open circuit diagnostic lead
4 - Video output to multimedia system control unit -J650- (RSE)
5 - Audio output to multimedia system control unit -J650- (RSE)
6 - Screen earth (audio)
7 - Audio output (right-side) to multimedia system control unit -J650- (RSE)
8 - Screen earth (video)
9 - Screen earth (audio)
10 - Audio input (left-side) 1 from multimedia system control unit -J650- (RSE)
11 - Audio input (right-side) 1 from multimedia system control unit -J650- (RSE)
12 - Video input 1 from multimedia system control unit -J650- (RSE)
13 - Screen earth 1 (video)
14 - Screen earth 2 (not used)
15 - Screen earth 2 (not used)
16 - Audio input (left-side) 2 (not used)
17 - Audio input (right-side) 2 (not used)
18 - Video input 2 (not used)
19 - Screen earth 2 (not used)
20 - I/O switch PIN from multimedia system control unit -J650- (RSE)
maros
Rozumieme Vášmu autu
Právě je po září 14, 2026 4:10 am
