Obsah fóra checksum.cz  »  Software  »  Autocom keygen verze 2.11.3 a 2.12.1
FUTO
Zaslal: čt srpen 09, 2012 22:45 pm Citovat
Copy by Anydraj
Heslo pouze privatně:
1: Zde zaregistrovanym uzivatelum
2: S vice jak 100 prispevky
Link:
http://www.ulozto.cz/xQ4gB2t/aukeg-zip
AUTOCOM CDP + ( PLUS )
AUTOCOM CDP + CARS 2011 Release 3
AUTOCOM CDP + TRUCKS 2011 Release 3
AUTOCOM CDP GENERIC 2011 Release 3
AUTOCOM CDP + CARS 2012 Release 1
AUTOCOM CDP + TRUCKS 2012 Release 1
AUTOCOM CDP GENERIC 2012 Release 1
AUTOCOM ADP i SDP
- TURN OFF your internet connection! ( for setup and activation only. after finish activation you can use internet )
- Insert a USB-memory stick with at least 1MB free space!
- SETUP software ( start.exe ) ,
- write product id ( for cars + : a-xxx-xxx ) , ( for trucks +: a-xxx-xxx ), ( for generic : a-xxx-xxx )
- Write the S/N and Hardware Key ( for Cars + : serial number; xxxxxxx, HW key; xxxxxxx )
( for Trucks + : serial number; xxxxxxx, HW key; xxxxxxx )
- contine
- click ON '' Activate via USB ''
- and you will have the '' FileActivation.xml '' file in USB-memory stick
- Use autocom keygen for activate '' FileActivation.xml '' file
in cd have keygen , in HELP folder
( close ativirus program , extrcah rar file . run AutoCom_CDP_Kg.exe )
- then you have activated FileActivation.xml file., copy into USB-memory stick .
and connect to USB-memory stick to computer. software will get infos in.
if not you can slect to manuel mode and open xml file.
in HELP folder have video file
eject to usb-memory
software will open then will have an error maybe ( Failed to load vehicle ...... )
close software
run '' Update_3_-_2011_Release_3 '' , write product id ( for cars + : a-xxx-xxx ) , ( for trucks +: a-xxx-xxx ), ( for generic : a-xxx-xxx )
then next
sofware will be open !!
Místo xxxxx Dáte vaše čísla verzí
Umí odemknout i Max module, Diesel max
FUTO
Zaslal: pá srpen 10, 2012 7:56 am Citovat
Uploaded with ImageShack.us
mattboy
Zaslal: st srpen 22, 2012 14:34 pm Citovat
Založen: 22.8.2012 Příspěvky: 1
Ahoj potřeboval bych heslo na ten zip soubor teda pokud by to šlo... moc díky Michael
macicek86
Zaslal: po srpen 27, 2012 22:49 pm Citovat
Založen: 21.8.2012 Příspěvky: 25
Jaky je rozdil mezi licensi "maxmodule", "dieselmax" a hw key?
lukaass7
Zaslal: pá září 21, 2012 7:37 am Citovat
Založen: 21.9.2012 Příspěvky: 1
Dobrý den, mohl byste mi prosím poslat heslo k otevření toho zipu. Předem děkuji, vím že nesplňuji 100 příspěvků , ale sháním to už velmi dlouho a moc by mi to pomohlo.
Zatím na shledanou
Panoramix
Zaslal: čt září 27, 2012 18:14 pm Citovat
Založen: 15.9.2010 Příspěvky: 79
lukaass7 napsal:
Zatím na shledanou
stači hladať je toho plný net
michal.filip.dj
Zaslal: pá říjen 05, 2012 10:13 am Citovat
Založen: 1.10.2012 Příspěvky: 1
Panoramix napsal:
lukaass7 napsal:
Zatím na shledanou
Nikde není....
poly33
Zaslal: čt říjen 18, 2012 14:21 pm Citovat
můžeš mi prosímtě poslat heslo k tomu zipu? byl bych ti moc vděčen díky Smile
matiz
Zaslal: so říjen 20, 2012 15:12 pm Citovat
Mohl bych poprosit o heslo k tomu aktivatoru, kolega si koupil francouzskou popelnici, nejede, netahne, nechce se ji ani na volnobeh. Pujcim si od kamose ten zazrak a prubnu to na tom pazoutovi. Jeho PC si pujcit nemuzu... Byl by nekdo te dobroty a poslal mi to heslo do SZ ?
Hodne mi to specha, navecer bych tam mel jet...
dufejo
Zaslal: so říjen 20, 2012 21:57 pm Citovat
Založen: 7.9.2012 Příspěvky: 9
Zdravím zde všechny a potřeboval bych poradit. V patek mi došel z číny autocom 2011.3 a nevím jak aktivovat software. Prosím o radu jak tento software aktivovat. Děkuji moc.
kluso
Zaslal: ne říjen 21, 2012 7:30 am Citovat
kontaktuj prodejce Smile
FUTO
Zaslal: ne listopad 11, 2012 17:27 pm Citovat
dufejo napsal:
Jestli jsi to nerozchodil pošli SZ Laughing
Zaslal: po listopad 12, 2012 6:22 am Citovat
KAŽDÝ SOFTÍK KTERÝ SI Z MÝCH UPLOADŮ STÁHNETE NEJDŘÍVE VYGOOGLUJTE AŤ SI ONĚM NĚCO PŘEČTETE ABY JSTE SI NEODBORNÝM ZÁSAHEM NĚCO NENÁVRATNĚ NEZNIČILI APOD.
(ZEJMÉNA NOVÁČCI)
ty jsi jenom zoufalý zlodějíček MASKOVANÝ internetem .....
máš na to se demaskovat a odtajnit a nebo se jen zbaběle schováváš za svým nickem ?
takový ten rádobyloupežníček co bohatým jakoby bere a svým jménem těm chudým dává ?
mně to spíše přijde jako že ten rádobyloupežníček něco najde v noci na smetišti za zámkem a přes den se chlubí jak ty boháče okradl , přemohl hradní stráž a chudým pomohl svojí chrabrostí a hrdinstvím....
CO TY NA TO MASKOVANÝ INTERNETOVÝ HRDINO ??
Laughing Laughing
Naposledy upravil DIGI-DELETED dne po listopad 12, 2012 6:47 am, celkově upraveno 1 krát.
FUTO
Zaslal: po listopad 12, 2012 6:43 am Citovat
Někdo to má ZADARA a někdo si to musí ukrást Laughing Laughing Laughing
Zaslal: po listopad 12, 2012 6:49 am Citovat
a nebo vyhrabat potmě na tom smetišti ... Mr. Green Mr. Green
viz fabia.exe....
Právě je po září 28, 2026 19:45 pm
