Obsah fóra checksum.cz  »  Diesel  »  Vynutena regeneracia DPF 3,0 V6 CAR Phaeton 2007
oliverko
Zaslal: út únor 05, 2013 16:21 pm Citovat
Cawte, nbere ziadny login na spustenie, 10016 ani 12233 ani ine neberie.
Nejake napady? Pripadne cez VAS?
Blika zhavenie a nudzak.
Zaslal: út únor 05, 2013 17:15 pm Citovat
Particle Filter Emergency Regeneration
Prerequisites:
Ignition ON
Engine ON (Idle)
Oil Temperature above 70 °C (see MVB 007.2)
Particle Filter Load below 68g (see MVB 104.3)
If the Particle Filter Load is above 68g the Particle Filter needs to be replaced since the car may burn down when regenerating.
Engine Hood CLOSED
Parking Brake ENGAGED
Transmission in (P)ARK
Temperatures at the Exhaust System may rise up to 300 °C!!!
No Fault Codes Stored
Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Control)
The Regeneration may take up to 40 minutes, the engine speed automatically increases to about 1500 RPM.
[Select]
[01 - Engine]
[Coding-II - 11]
Start Regeneration by Entering 10016.
[Do It!]
[Meas. Blocks - 08]
Select all 3 Groups at once 100, 101 and 102
[Go!]
MVB 100.1: Engine Speed
MVB 100.3: Regeneration Counter/Timer
MVB 100.4: Regeneration Abort recognized (0 = No Abort/1 = Abort recognized)
MVB 101.4: Regeneration Status (001 = Heating Up, 010 = Regeneration, 100 = Cooling Down)
MVB 102.1: Temperature before Catalyst
MVB 102.2: Temperature before Particle Filter
[Done, Go Back]
[Close Controller, Go Back - 06]
Pokud jsou splněny všechny podmínky tak to musí jít Wink
oliverko
Zaslal: út únor 05, 2013 17:39 pm Citovat
Vyfuk som dostal na maximalne 259,8
v pameti ostava chyba FAP plny.
Login neakceptuje!!! 10016 motor BMK Ja tam mam motor CAR.
Mozes mi poradit nastavenie teda prisposobenie po vymene DPF? Ak vies mozes aj vo vas. ja som tym zabil cely den... Na ten login proste pise incorect.
Ak je dobry login, musi ho zobrat. Ci uz zacne alebo nezacne regenerovat..
Zaslal: út únor 05, 2013 18:05 pm Citovat
login zadáváš do položky kodování II pak ho to akceptuje pkud ho zadáš do security acces tak ho to samozřejmě nevezme
a pokud je ten filtr zanesenej víc jak 70% tak regeneraci nespustíš
ale jak se říká s oblibou v čechách FAP vyříznout do šrotu budou kačky a sw vypnout Mr. Green Mr. Green Mr. Green Mr. Green Mr. Green
Zaslal: út únor 05, 2013 19:27 pm Citovat
a za dva roky... Laughing
Zaslal: út únor 05, 2013 19:59 pm Citovat
vaha napsal:
jé pane neměl by jste FAP a nemoh by jste mě ho zapnout? Mr. Green Mr. Green Mr. Green Mr. Green
Sayllo
Zaslal: út únor 05, 2013 20:34 pm Citovat
martin napsal:
Jo to hej, ale povedzme ze pan si zela mat vsetko ako sa vravi, naporiadku Razz
Cize asi kupim aj novy DPF. Len potom ako ho resetovat? Myslim ze to ide cez VAS lahsie, ale VAS som uz nevidel nejaky ten rok Laughing
Nemate nejake odkazy na tento konkretny motor ako to vyresetovat? Nechcem to blokovat, skratka iba reaktivovat.
A ako pokial to nezobere login, je to jednoznacne nesplnenie podmienok? Lebo ono to ten login odmietne skratka ako bankomat zly pin... Tusim error-11. a samozrejme coding II Cool
Dik
Sayllo
Zaslal: út únor 05, 2013 22:43 pm Citovat
martin napsal:
Takze pokial budem stale cpat 10016 tak to urcite nepojde, a jak tak pozeram tak login sa moze zadavat aj na sec. acces, alebo coding II kazdopadne ale tento
Motory Common-Rail, 2,7/3,0 TDI 6V, EDC17
Oprávnění přístupu 27971!!!! Laughing
Zaslal: út únor 05, 2013 22:45 pm Citovat
nj nějak mě nedocvaklo že je tam edc 17 ten postup co jsem psal je na edc16 Rolling Eyes
tomík
Zaslal: st únor 06, 2013 1:01 am Citovat
vyndanej fap v CZ problém ? néé kdo by poznal že výfuk rovně naftalčka a koncovka od sazí že by byl fap po smrti?to se v čechách udělá jako výběrový řízení vyhraje nejdražší firma a bude jezdit ze zkušebnou za miliardy a napojej se na auto tísíc kabelama pak řidič co doveze ten aparát za nesmysl párek v levačce a pravačkou strčí prst do vejfuku votře vnitřek a řekne fap death Smile mě vomejou jak tohle dopadne 2012 fap off 2015 zase fap onn a ejhle bude prace ale pozor zalohujte soubory podle vin pak bude poloviční práce to hodit do origa Very Happy
Zaslal: st únor 06, 2013 7:41 am Citovat
to je stejně komické : na jedné straně se projebají milardy za nápady zelených mozků (různé řepky , biolíh a podobné hovadiny ) a na druhé straně jsou majitelé aut bráni jako rukojmí a výrobci po nich chtějí nesmyslné částky za filtr který stojí na něco 10 000 a na něco 100 000 , ačkoliv jde v podstatě o podobnou věc s podobnými výrobními náklady ....
kdyby se ty projebane miliardy za různé "bionápady" radší vrazily do toho,aby cena filtru byla v nějakých rozumných mezích , tak by se nikdo nezabýval jejich odstranováním...
asi už je nejvyšší čas si zvolit nějakou vládu selského rozumu , vládu kravat už máme dlouho a kam jsme s ní dostali ? Laughing Laughing
Sayllo
Zaslal: st únor 06, 2013 20:30 pm Citovat
martin napsal:
Vpohode... Dnes som to vycistil vyresetoval a beha to jako nove...Az na to ze od 3,0 CR V6 som teda skutocne cakal aj nejaky vykon...
Sayllo
Zaslal: st únor 06, 2013 20:32 pm Citovat
Doriti
Právě je ne srpen 30, 2026 11:46 am
