| Obsah fóra checksum.cz » Panely přístrojů, immo » A4 TT 1.8 99rok |
Strana 1 z 1 |
| RomanP |
Zaslal: so květen 16, 2020 12:38 pm |
Založen: 29.11.2008
A4 TT 1.8 99rok
Nema prosim nekdo zapojeni na stole. Nesviti mi displej KM.
Mam i jinou pristrojovku a tak rad bych to pripojil na stole.
Pristrojovka ma zeleny a modry konektor a uprostred nahore pristrojonky modul se třemi draty.
oznaeni 8N1 919 860 C a je tam motorola HC08
popripade poslu foto dash
| maros4341 |
Zaslal: so květen 16, 2020 17:05 pm |
Založen: 23.2.2007
to snad nemyslis vážne....?!
máš vybavenie ako profi autoservis
potom dáš takúto požiadavku na pomoc
Nemoznáš servisný manual VW AUDI SEAT SKODA ? ELSA ?
Niekedy už prestávam chápať tento automobilový svet
Multi-pin connector, 32-pin, blue
1 - Terminal 15
2 - Brake pad wear
3 - Speedometer (output 1)
4 - Not used
5 - Fuel gauge sender
6 - Fuel tank warning OBD 2
7 - Terminal 31 (sensor earth)
8 - Coolant temperature
9 - Terminal 31 (load earth)
10 - Oil pressure 2 (high)
11 - Engine speed signal
12 - Air conditioner shut-off
13 - Electronic throttle / glow period warning lamp
14 - Self-levelling suspension
15 - Terminal 58d
16 - Turn signal (trailer)
17 - Main beams
18 - Turn signal (left-side)
19 - Not used
20 - Terminal 58s
21 - Driver's door contact
22 - Coolant level low
23 - Terminal 30
24 - Terminal 31 (load earth)
25 - Fuel consumption signal
26 - Right parking light
27 - Left parking light
28 - Speedometer input
29 - Brake
30 - S contact
31 - Speedometer (output 2)
32 - ESP/ASR (TCS)
Multi-pin connector, 32-pin, green
1 - Door contact (all doors)
2 - Transponder 1
3 - Not used
4 - Not used
5 - W wire
6 - Rear lid
7 - Turn signal (right-side)
8 - Not used
9 - Not used
10 - Airbag
11 - Standing time output
12 - Terminal 61/charge warning
13 - Parking brake / BRAKE
14 - CHECK
15 - Oil level / oil temperature
16 - Not used
17 - Transponder 2
18 - CAN high speed, power train (+)
19 - CAN high speed, power train (–)
20 - CAN high speed, power train (screening)
21 - ABS
22 - CAN low speed, convenience (+)
23 - CAN low speed, convenience (–)
24 - CAN low speed, convenience (screening)
25 - Bonnet
26 - Not used
27 - Belt buckle
28 - K wire
29 - Ambient temperature input
30 - Not used
31 - Selector lever display
32 - Not used
_________________ maros
Rozumieme Vášmu autu
| RomanP |
Zaslal: so květen 16, 2020 21:08 pm |
Založen: 29.11.2008
| Dekuji moc. Info SZ
Právě je st říjen 21, 2026 7:23 am
