Octavia 99-00
trino
Octavia 99-00
Příspěvek od trino »
Ahoj panove stala se nam takova blba vec kamosovi vypovedeli budiky. muzete mi nekdo zdelit ktere piny jsou ktere na budikach diky. Dalsi vec bych potreboval je premosteni cerpadla aby jsme mohli nouzove dojet do dilny diky
Příspěvek od John »
zde, jak ti nejdou ty budiky ?
32 pin connector, blue:
1 - terminal 15 positive
2 - warning lamp for turn signal, right
3 - ouptut signal 1 from speedo AKA, speed signal(needed for NAVI install)
4 - warning lamp for trailer towing
5 - fuel gauge
6 - airbag
7 - terminal 31, sender earth
8 - coolant temp gauge
9 - terminal 31, earth
10 - oil pressure switch
11 - vacant
12 - warning lamp for alternator, terminal 61
13 - backrest lock warning lamp (certain countries only)
14 - warning lamp for rear fog light
15 - vacant
16 - open tailgate/boot lid warning lamp (CCO)
17 - warning lamp for main beam, terminal 56a
18 - warning lamp for turn signal. left
19 - ABS
20 - dash panel insert illumination, terminal 58b (needed for NAVI install)
21 - signal for driver's door open
22 - coolant shortage indicator
23 - terminal 30, positive
24 - terminal 31, earth
25 - self diagnosis/K-wire (needed for NAVI install)
26 - parking light right, signal for "lights on" warning buzzer
27 - parking light left, signal for "lights on" warning buzzer
28 - input signal to electronic speedo
29 - warning lamp for brake system
30 - S-contact (needed for Navi install)
31 - Seat-belt warning system
32 - vacant
32-pin, green:
1 - vacant
2 - reading coil for immo 1
3 - warning lamp for side lights
4 - data bus (CAN), screening for input signals
5 - W-wire
6 - washer fluid shortage
7 - brake pad wear
8 - vacant
9 - vacant
10 - vacant
11 - signal for vehicle stationary
12 - aircon system cut-off
13 - warning lamp for hand brake
14 - warning lamp for ASR/ESP
15 - vacant
16 - vacant
17 - reading coil for immo 2
18 - oil temp & level warning signals
19 - data bus (CAN), high input signal
20 - data bus (CAN), low input signal
21 - vacant
22 - bonnet switch input signal
23 - MFI call up button, top
24 - MFI call up button, bottom
25 - MFI memory switch - reset
26 - ambient temp input signal
27 - data bus (CAN), high output signal
28 - data bus (CAN), low output signal
29 - vacant
30 - vacant
31 - vacant
32 - vacant
dodi911
Příspěvek od dodi911 »
Pokial myslis premostenie cerpadla koli tomu, ze ti klakli budiky a blokuje to immo, tak ti to nepomoze.
sazimam
Re: Octavia 99-00
Příspěvek od sazimam »
trino píše:Ahoj panove stala se nam takova blba vec kamosovi vypovedeli budiky. muzete mi nekdo zdelit ktere piny jsou ktere na budikach diky. Dalsi vec bych potreboval je premosteni cerpadla aby jsme mohli nouzove dojet do dilny diky
Myslis "premosteni" vstrikovaciho cerpadla u dieselu ??
